OGC Filter not working with covrage and featuretypes layer combination
Key: GEOS-1484
URL: http://jira.codehaus.org/browse/GEOS-1484
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.5.3
Environment: Microsoft Windows XP,
GeoServer 1.5.3,
Java 1.5.0_05
Reporter: Ganesh Jothikumar
Assignee: Andrea Aime
Attachments: PageClick.log, PageLoad.log
1) I have created a coverage (layer name : top:basemap) based on a JPG file accompanie with a world file.
2) I have created a featuretype (layer name : topp:devicelocationview) which is based on a PostGIS view
Now I am overlaying the featuretype layer above the coverage layer using the below URL
This works perfectly fine.
Now I want to filter the data queried from the feature type. So I am using OGC filter in teh URL as well. Since I have no filter for the coverage I am using '()' for the filter for the coverage.
But the filter is not getting applied. I have enabled ALL logs and the log output is attached as file (PageLoad.log)
Now when I click on the map to GetFeatureInfo I get a WMS exception. The log for the click action is attached as (PageClick.log)
This works perfectly fine if I the URL has only the featuretype layer and the filter is applied on it like below
The problem seems to come only when it is overlayed on top of a coverage
Also this doesn't seem to happen when we overlay one featuretype over another featuretype and apply filters as in the following example (http://docs.codehaus.org/display/GEOSDOC/WMS+vendor+parameters).
If this is a bug please let me know a workaround with example on how to proceed with this.
