[Geoserver-devel] [jira] Created: (GEOS-1489) Geoserver returns more than maxFeatures if more than 1 layer is requested in WFS request
                 Key: GEOS-1489
                 URL: http://jira.codehaus.org/browse/GEOS-1489
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.6.0-beta4
            Reporter: Stefan Hansen
            Assignee: Andrea Aime
         Attachments: diff.txt
If in a WFS request features from more than 1 layer are requested, Geoserver (most likely) returns more features than specified in maxFeatures.
If a WFS request contains more than 1 layer, then Geoserver splits it up in single requests; for each layer one request. In the request for the first layer maxFeatures is set to the original value. If this first request returns n features, maxFeatures is set in the 2nd request to (original_maxFeatures - n). Usually, (original_maxFeatures - n) becomes at some stage 0. But if maxFeatures is ste to 0, Geoserver will return an unlimited number of features.
As far as I know the problem is in GetFeature.java in the method public FeatureCollectionType run(GetFeatureType request).
The requests for each layer are sent in a for loop. One of the conditions to end the for-loop is (count <= maxFeatures). If you remove the '=', everything should work fine.
