Can't edit/add style when port is not 8080
Key: GEOS-1491
URL: http://jira.codehaus.org/browse/GEOS-1491
Project: GeoServer
Issue Type: Bug
Components: UI
Affects Versions: 1.6.0-beta4
Environment: Windows XP, Tomcat 6.0.14, GeoServer 1.6 beta 4
Reporter: Jared Erickson
Assignee: Andrea Aime
To reproduce, configure tomcat to run under a different port (8090 instead of 8080). Start tomcat, add the geoserver web app, login to the config section, navigate to data and then style. Click new or select an existing style and click edit. It appears that geoserver tries to load the editarea/edit_area_full.js on port 8080 so it just hangs.
