[Geoserver-devel] [jira] Created: (GEOS-1494) Update schemaData output to new ExtendedData proposal on kml-ows5 output
                 Key: GEOS-1494
                 URL: http://jira.codehaus.org/browse/GEOS-1494
             Project: GeoServer
          Issue Type: Task
          Components: Google Earth KML Output
            Reporter: Chris Holmes
            Assignee: Andrea Aime
             Fix For: Community
         Attachments: kml-ext-data-proposal.pdf
We've made a proposal for improving the ExtendedData element of KML. I am attaching this as a pdf. It was well received, so we should go ahead and implement.
It should replace the SchemaData stuff in kml-ows5 output in the kml3 community module. Though we probably should keep that code around, since it will be quite useful to be able to have the option to output that with KML 2.2, since these changes won't make it in for that, and it will likely be released with the schema data. We should make it an option though, I'll talk about that in another bug though.
