Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-151
Here is an overview of the issue:
Key: GEOS-151
Summary: User Interface page for login.
Type: New Feature
Status: Open
Priority: Critical
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Components:
Struts
Fix Fors:
1.2.0
Versions:
1.2-beta
Assignee: Jody Garnett
Reporter: Chris Holmes
Created: Wed, 7 Apr 2004 9:49 AM
Updated: Wed, 7 Apr 2004 9:49 AM
Description:
I added code to set the log in using adminUserName and adminPassword. It mostly works, and I think it will all work if there's a new page for setting the user name and password. I'm not sure if it should be part of the global config page or if it should have its own. Once that's done it should fix a small bug I'm having, when the GlobalConfig is submitted I lose the value of the adminUserName and Password that I set in the xml file, they reset to the defaults. I can follow the code along, and I tried to put it in form and action, as well as config, but got no success. So I'm going to leave that code out, as I figure it may just mess you guys up further. But yeah, this is pretty much needed for 1.2.0 - I forgot about it in the irc.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
