[Geoserver-devel] [jira] Created: (GEOS-153) Bug clipping data to a given bbox
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-153
Here is an overview of the issue:
        Key: GEOS-153
    Summary: Bug clipping data to a given bbox
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: 2 days
Time Spent: Unknown
  Remaining: 2 days
    Project: GeoServer
Components:
             WFS
   Assignee: Chris Holmes
   Reporter: Jeroen Christiaens
    Created: Fri, 9 Apr 2004 2:22 AM
    Updated: Fri, 9 Apr 2004 2:22 AM
Environment: GeoServer
Tomcat 4.1.29
Description:
I have a shapefile served by GeoServer WFS. It's a polygonlayer that consists of one outerboundary polygon (LinearRing) and none internal boundaries. The max extends I can measure of the whole shapefile are (LON/LAT)
6<-->8.16 (east<->west) and 49.5<-->50.95 (north-south).
If I access the file without a bounding box clip, I get the correct gml. I receive back data and can use/read it properly. OK
If I add a bounding box "&bbox=xmin,ymin,xmax,ymax" with values that contain the whole shapefile, I get the exactly the same data. OK
If I add a bounding box that contains some internal area, I will get back again the full result because that is the boundary. OK
If I add another boundary that only overlaps with the North-West part of the full area, I don't get ANY results... where I expect to have also the full border because there is an overlap with the given bbox and the area.
Try...
[...]wfs?request=GetFeature&typename=topp:test --> returns the full GML
[...]wfs?request=GetFeature&typename=topp:test&bbox=6,49.8,6.3,50.2 --> returns result like it should.
[...]wfs?request=GetFeature&typename=topp:test&bbox=3.27,50.7,7.3,53.6 --> return an empty GML result (see below) Look at the strange results for the boundedBy coordinates.
What is going on here? Anyone any idea? It is very strange because if I zoom on a map, sometimes the area is drawn and sometimes not (and then it looks stupid because you see the hole :frowning: that it creates by not displaying it (it doesn't get a result from the geoserver)
Jeroen
<?xml version="1.0" encoding="UTF-8" ?>
- <wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:topp="http://www.openplans.org/topp&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.openplans.org/topp http://localhost:8888/geoserver/wfs/DescribeFeatureType?typeName=topp:test http://www.opengis.net/wfs http://localhost:8888/geoserver/data/capabilities/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
- <gml:boundedBy>
- <gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;
  <gml:coordinates decimal="." cs="," ts="">0,0 0,-1 -1,-1 -1,0</gml:coordinates>
  </gml:Box>
  </gml:boundedBy>
  </wfs:FeatureCollection>
I have added the necessairy files...
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
