Default attribute points in KML output are too big and rasterized
Key: GEOS-1542
URL: http://jira.codehaus.org/browse/GEOS-1542
Project: GeoServer
Issue Type: Bug
Components: Google Earth KML Output
Affects Versions: 1.6.0-RC1
Environment: Tomcat 6, Java 1.6, Ubtuntu 7.10
Reporter: Jason Pickering
Assignee: Andrea Aime
Priority: Minor
Attachments: DefaultPolygonPoints.jpg
It does not seem that it is possible to change the default attribute point renderer when polygons are output to KML via the KML reflector. Is it possible to specify with an SLD what the default attribute point render should be?
