kml-ows5
Key: GEOS-1561
URL: http://jira.codehaus.org/browse/GEOS-1561
Project: GeoServer
Issue Type: Bug
Reporter: Arne Kepp
Assignee: Andrea Aime
Priority: Minor
Triple-checked that everything had been built with Java 1.4.2:
[ak@anonymised.com geoserver]$ mvn --version
Maven version: 2.0.7
Java version: 1.4.2_16
OS name: "linux" version: "2.6.23.1-49.fc8" arch: "i386"
Built geotools 2.4.x:
mvn clean install -Djava.awt.headless=true
(ok)
Built GeoServer 1.6.x
mvn clean install -Dcommunity
.... everything okay for a while (geoserver/data installs fine too), then ....
[INFO] ----------------------------------------------------------------------------
[INFO] Building KML OWS5
[INFO] [clean:clean]
[INFO] Deleting directory /home/ak/testagain/geoserver/community/kml-ows5/target
[INFO] Deleting directory /home/ak/testagain/geoserver/community/kml-ows5/target/classes
[INFO] Deleting directory /home/ak/testagain/geoserver/community/kml-ows5/target/test-classes
[INFO] Deleting directory /home/ak/testagain/geoserver/community/kml-ows5/target/site
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 5 source files to /home/ak/testagain/geoserver/community/kml-ows5/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to /home/ak/testagain/geoserver/community/kml-ows5/target/test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[3,31] package org.geoserver.data.test does not exist
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[4,25] cannot resolve symbol
symbol : class WMSTestSupport
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[8,33] cannot resolve symbol
location: class org.geoserver.wms.responses.map.kml.KMLOWS5Test
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[14,37] package MockData does not exist
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[14,76] package MockData does not exist
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[11,23] cannot resolve symbol
symbol : method getAsDOM (java.lang.String)
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[19,8] cannot resolve symbol
symbol : method assertEquals (int,int)
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[21,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[23,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[24,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[31,37] package MockData does not exist
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[31,76] package MockData does not exist
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[28,23] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[37,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[38,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[39,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[40,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[41,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[48,37] package MockData does not exist
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[48,76] package MockData does not exist
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[45,23] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[54,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[55,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[56,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[57,8] cannot resolve symbol
/home/ak/testagain/geoserver/community/kml-ows5/src/test/java/org/geoserver/wms/responses/map/kml/KMLOWS5Test.java:[58,8] cannot resolve symbol
[INFO] Total time: 4 minutes 29 seconds
[INFO] Finished at: Thu Nov 29 18:08:25 EST 2007
[INFO] Final Memory: 27M/63M
