Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-157
Here is an overview of the issue:
Key: GEOS-157
Summary: Tomcat 4x action servlet failure
Type: Bug
Status: Open
Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Components:
Struts
Versions:
1.2-beta
Assignee: Chris Holmes
Reporter: Mark Adams
Created: Wed, 14 Apr 2004 11:43 AM
Updated: Wed, 14 Apr 2004 11:43 AM
Environment: Win2K, IIS, Tomcat 4.1.24, Java SDK 1.4.2
Win2K, IIS, Tomcat 4.1.24, Java SDK 1.4.2 OR
Win2K, Apache2, Tomcat 4.1.24, Java SDK 1.4.2
Description:
I can install geoserver OK, but as soon as I change *anything* in the configuration (using the web admin pages), when I restart Tomcat the next time the “action” servlet is disabled. I can only “fix” this by removing geoserver and starting all over. My Tomcat log records the text included below (I’ve left out a lot, just copied where the error occurs).
2004-04-13 15:10:43 StandardManager[/geoserver]: Seeding of random number generator has been completed
2004-04-13 15:10:43 StandardWrapper[/geoserver:default]: Loading container servlet default
2004-04-13 15:10:45 action: null
java.lang.NullPointerException
at java.util.logging.Handler.setLevel(Handler.java:230)
at org.vfny.geoserver.global.Log4JFormatter.init(Log4JFormatter.java:216)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadGlobal(XMLConfigReader.java:345)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadServices(XMLConfigReader.java:201)
at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:157)
at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:132)
at org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:88)
at org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1158)
at org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
at javax.servlet.GenericServlet.init(GenericServlet.java:256)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:935)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:823)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:3420)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:3608)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:821)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:807)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:579)
at org.apache.catalina.core.StandardHostDeployer.install(StandardHostDeployer.java:307)
at org.apache.catalina.core.StandardHost.install(StandardHost.java:772)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:492)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:400)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:718)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:358)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:166)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1196)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:738)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1188)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:347)
at org.apache.catalina.core.StandardService.start(StandardService.java:497)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:2190)
at org.apache.catalina.startup.Catalina.start(Catalina.java:512)
at org.apache.catalina.startup.Catalina.execute(Catalina.java:400)
at org.apache.catalina.startup.Catalina.process(Catalina.java:180)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:203)
2004-04-13 15:10:45 StandardWrapper[/geoserver:action]: Marking servlet action as unavailable
2004-04-13 15:10:45 StandardContext[/geoserver]: Servlet /geoserver threw load() exception
javax.servlet.UnavailableException
at org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1169)
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
