[Geoserver-devel] [jira] Created: (GEOS-1570) Shapefile index building is very memory hungry
                 Key: GEOS-1570
                 URL: http://jira.codehaus.org/browse/GEOS-1570
             Project: GeoServer
          Issue Type: Improvement
          Components: WMS
    Affects Versions: 1.6.0-RC1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.6.1
Current shapefile index building code is adequate only for small and mid sized shapefile (less than 100MB). Trying to build the index for a 400MB shapefile resulted to be impossible even providing the VM with 2GB of memory.
For the moment, tell users to generate the indexes using shptree, and then investigage what hsptree is doing and replicate it (shptree is generating indexes with a small amount or required memory).
