[Geoserver-devel] [jira] Created: (GEOS-1592) Oracle user must be the schema owner
                 Key: GEOS-1592
                 URL: http://jira.codehaus.org/browse/GEOS-1592
             Project: GeoServer
          Issue Type: Bug
          Components: Oracle
    Affects Versions: 1.6.0-RC1
            Reporter: Paul Austin
            Assignee: Andrea Aime
The current oracle implementation requires that the tables have an entry in USER_SDO_GEOM_METADATA which means either the login user has to be the owner of the schema or each user must have entries in their USER_SDO_GEOM_METADATA. Could this be changed to use ALL_SDO_GEOM_METADATA to avoid this requirement?
