ResultType is not being parsed into a ResultTypeType for GetVersionedFeature
Key: GEOS-1598
URL: http://jira.codehaus.org/browse/GEOS-1598
Project: GeoServer
Issue Type: Improvement
Components: WFS, Versioning
Affects Versions: 1.6.0-RC1
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 1.6.1
When parsing GetVersionedFeature (a pure GetFeature extension) resultType is assigned to "results" (even if the xml request does not contain it) and it's not parsed into a ResultTypeType so a class cast excetion occurrs.
The request is:
{code}
<wfsv:GetVersionedFeature service="WFSV" version="1.1.0"
xmlns:topp="http://www.openplans.org/topp"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:wfsv="http://www.opengis.net/wfsv"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfsv
http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfsv.xsd
http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd">
<wfs:Query typeName="topp:archsites">
<ogc:Filter>
<ogc:FeatureId fid="archsites.1"/>
<ogc:FeatureId fid="archsites.2"/>
<ogc:FeatureId fid="archsites.26"/>
</ogc:Filter>
</wfs:Query>
</wfsv:GetVersionedFeature>
{code}
and can be run against the versioning configuration. I still haven't committed the code thought, so you can't try it just now (as I told you, I'm working on 1.6.x since this is critical for the NY maps people so I first have to make sure I'm not breaking anything with my changes). Will ping you when stuff is committed (and close this if it turns out to be a config error on my part, I just want to write it down so I won't forget about it).
