[Geoserver-devel] [jira] Created: (GEOS-1609) reflect malfunction
reflect malfunction
                 Key: GEOS-1609
                 URL: http://jira.codehaus.org/browse/GEOS-1609
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.0-RC1
            Reporter: Mikael Hamström
            Assignee: Andrea Aime
when using the reflect function, following behavior occur.
example of request:
.../wms/reflect?layers=layername&width=200
as result the layer is presented as png, but if you use exactly the same url again the resulting layer (png) is smaller in size.
doing the same request several times the very last resonse will be a very small png file ....
