[Geoserver-devel] [jira] Created: (GEOS-1657) NPE thrown when configuring a shapefile with no .prj information
                 Key: GEOS-1657
                 URL: http://jira.codehaus.org/browse/GEOS-1657
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.6.0-RC2
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.6.0, 1.7.0-beta1
When trying to configure a shapefile with no .prj file attache the following exception occurs:
2008-01-08 16:26:17.140::WARN: /geoserver/config/data/storeSubmit.do
java.lang.NullPointerException
  at org.geotools.referencing.CRS.lookupIdentifier(CRS.java:808)
  at org.geotools.referencing.CRS.lookupEpsgCode(CRS.java:833)
  at org.vfny.geoserver.config.FeatureTypeConfig.lookupSRS(FeatureTypeConfig.java:253)
  at org.vfny.geoserver.config.FeatureTypeConfig.<init>(FeatureTypeConfig.java:203)
  at org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(DataDataStoresEditorAction.java:197)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
