[Geoserver-devel] [jira] Created: (GEOS-1668) Memory leak in WMS response handling
                 Key: GEOS-1668
                 URL: http://jira.codehaus.org/browse/GEOS-1668
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.0-RC2
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.6.0, 1.7.0-beta1
DefaultMapContext attaches listeners to the feature source, these listeners are referenced by FeatureListenerManager and are never cleaned up, meaning each request builds up a new featuresource/defaultmapcontext couple in featureListenerManager. The leak is usually small, but can become sizeable if the styles used by the map context are big.
We should clean up after ourselves when the response is done (the cleanup code there, but for some strange reason it has been commented out when merging the WCS branch one year ago), but at the same time FeatureListenerManager should be smarter and use weak references to avoid this kind of issues
     [ http://jira.codehaus.org/browse/GEOS-1668?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Andrea Aime reopened GEOS-1668:
Just to change the fixed-fox version
                Key: GEOS-1668
            Project: GeoServer
         Issue Type: Bug
         Components: WMS
            Fix For: 1.6.0-RC3
