release directory contains jars
Key: GEOS-1682
URL: http://jira.codehaus.org/browse/GEOS-1682
Project: GeoServer
Issue Type: Task
Affects Versions: 1.6.0-RC3
Reporter: Gabriel Roldán
Assignee: Justin Deoliveira
Priority: Critical
Fix For: 1.6.0
The geoserver release directory contains some jars that I'm quite sure there shouldn't be there. The arcsde one for sure.
I guess we should just remove them, yet I'm assigning this issue to you Justin as you may know more about the release set up.
The jars in there are:
{code}
./jetty/start.jar
./extensions/mysql/mysql-connector-java-3.0.17.jar
./extensions/arcsde/gt2-arcsde.jar
./extensions/oracle/ojdbc14.jar
./wrapper/bin/wrapper/lib/wrapper.jar
./wrapper/bin/wrapper/lib/wrappertest.jar
{code}
