[Geoserver-devel] [jira] Created: (GEOS-1685) GeoServer won't startup even after successfull installation
                 Key: GEOS-1685
                 URL: http://jira.codehaus.org/browse/GEOS-1685
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.6.0-RC2
         Environment: Windows XP home and also Windows 2003 Server
            Reporter: Paolo Gallo
            Assignee: Andrea Aime
            Priority: Blocker
Installed GeoServer 1.3 RC 2 on windows 2003 server, using windows installer, installation process ok, JDK 6 already installed startup fails, environment variables ok, data_dir permission ok , What could be wrong ???
here is the log :
0 [main] INFO org.mortbay.log - Logging to
org.slf4j.impl.SimpleLogger@anonymised.com via org.mortbay.log.Slf4jLog
562 [main] INFO org.mortbay.log - jetty-6.0.2
2312 [main] INFO /geoserver - Loading Spring root WebApplicationContext
14 gen 14:49:28 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: C:\Programmi\GeoServer 1.6.0-RC2\data_dir
14 gen 14:49:52 WARN [geoserver.global] - log4jConfigFile
'DEFAULT_LOGGING.properties' couldn't be found in the data
dir, so GeoServer will install the
various logging config file into the data dir, and then try to find it
again.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
14 gen 14:49:52 INFO [geoserver.global] - StdOut logging enabled. Log
file also
output to 'C:\Programmi\GeoServer 1.6.0-RC2\data_dir\logs\geoserve
r.log'
14 gen 14:49:53 INFO [geoserver.global] - Loading feature type
'DS_giant_polygon
:::giant_polygon' (layer 1/14)
'DS_poi:::poi' (l
ayer 2/14)
'DS_poly_landmark
s:::poly_landmarks' (layer 3/14)
'DS_tiger_roads::
:tiger_roads' (layer 4/14)
'sfArchsites:::ar
chsites' (layer 5/14)
'sfBugsites:::bug
sites' (layer 6/14)
'sfRestricted:::r
estricted' (layer 7/14)
'sfRoads:::roads'
(layer 8/14)
'sfStreams:::stre
ams' (layer 9/14)
'states_shapefile
:::states' (layer 10/14)
'tasmania_cities:
::tasmania_cities' (layer 11/14)
'tasmania_roads::
:tasmania_roads' (layer 12/14)
'tasmania_state_b
oundaries:::tasmania_state_boundaries' (layer 13/14)
'tasmania_water_b
odies:::tasmania_water_bodies' (layer 14/14)
32187 [main] INFO /geoserver - Initializing WebApplicationContext for
Struts Act
ionServlet 'action', module ''
32672 [main] INFO org.mortbay.log - Started SelectChannelConnector @
0.0.0.0:8081
