KVP parsing can NPE depending on the container if an empty parameter is used
Key: GEOS-1687
URL: http://jira.codehaus.org/browse/GEOS-1687
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.6.0-RC3
Reporter: Andrea Aime
Assignee: Andrea Aime
Priority: Blocker
Fix For: 1.6.0
Tim just managed to get an NPE on atlas.openplans.org by doing this request:
and the stack trace is:
{code}
org.geoserver.platform.ServiceException: java.lang.NullPointerException
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1163)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:198)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:584)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:354)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:885)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.NullPointerException
at org.geotools.util.Converters.convert(Converters.java:123)
at org.geotools.util.Converters.convert(Converters.java:90)
at org.geoserver.ows.KvpRequestReader.read(KvpRequestReader.java:140)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:149)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1002)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:371)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:185)
... 41 more
{code}
Now, I've looked into the code and this seems to be possible only if the HttpRequest kvp map contains null values inside... which is very odd, and I don't know how to reproduce...
apparently from the Map interface specification implementors are allows to have maps that do accept nulls both as keys and as values...
