[Geoserver-devel] [jira] Created: (GEOS-169) Update Drifver remove encoding, fix memory leak
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/browse/GEOS-169
Here is an overview of the issue:
        Key: GEOS-169
    Summary: Update Drifver remove encoding, fix memory leak
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
   Versions:
             1.2.0-rc1
   Assignee: Chris Holmes
   Reporter: Jody Garnett
    Created: Mon, 31 May 2004 5:12 PM
    Updated: Mon, 31 May 2004 5:12 PM
Environment: Postgis DataStore and GeoServer
Description:
cholmes There's nothing to be done, really, though.
cholmes We just have to remove the calls to setEncoding.
cholmes And use the standard driver.
aaime Yep
cholmes And tell people to use at least 7.2 (or was it 7.3)
cholmes I'm fine with that requirement for people who want internationalization.
cholmes I just have to test with geoserver, so that's all on me.
jgarnett 7.3 I think ... and we are still not sure if it will fixe our resource leak.
aaime In fid-exp I also fixed a few tests not passing... last time I checked everything was working (probably there are no tests hitting the encoding side of the code?)
cholmes So Jody, create a jira task for me on geoserver to update the postgres driver, along with encoding, and then you can test the resource leak.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
