[Geoserver-devel] [jira] Created: (GEOS-1699) GetCoverage band selection does not work for all bands but the first one
                 Key: GEOS-1699
                 URL: http://jira.codehaus.org/browse/GEOS-1699
             Project: GeoServer
          Issue Type: Bug
          Components: WCS
    Affects Versions: 1.6.0-RC3
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.6.0, 1.7.0-beta1
Any attempt at a band select besides the first one fails due to a bug in the GeoTools bandselect operation. This affects both wcs 1.0 and wcs 1.1.
A stack trace from the wcs 1.1.1 tests looks like:
{code}
org.vfny.geoserver.wcs.WcsException: java.lang.ArrayIndexOutOfBoundsException: 1
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:326)
  at org.geoserver.wcs.GetCoverageTest.executeGetCoverage(GetCoverageTest.java:50)
  at org.geoserver.wcs.GetCoverageTest.testRangeSubset(GetCoverageTest.java:194)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUnit3TestReference.java:130)
  at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:460)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:673)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:386)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:196)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 1
  at org.geotools.coverage.processing.operation.BandSelector2D.create(BandSelector2D.java:196)
  at org.geotools.coverage.processing.operation.SelectSampleDimension.doOperation(SelectSampleDimension.java:152)
  at org.vfny.geoserver.util.WCSUtils.bandSelect(WCSUtils.java:478)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:282)
  ... 18 more
{code}
