[Geoserver-devel] [jira] Created: (GEOS-1710) Geoserver complains about a database not being a versioned when in fact it is.
                 Key: GEOS-1710
                 URL: http://jira.codehaus.org/browse/GEOS-1710
             Project: GeoServer
          Issue Type: Bug
          Components: Versioning
    Affects Versions: 1.6.x
         Environment: Ubuntu 7.10, Java 1.6, Tomcat 6,
            Reporter: Ivan Willig
            Assignee: Andrea Aime
         Attachments: error.txt
I have installed Geoserver from the 1.6.x branch in tomcat 6 using Java 1.6. I also dump my old versioned postgis database and started over again. I added the spatial config to postgis and than added the database to geoserver as an versioning postgis data store. At this point everything seems fine and my database show up in the up in my featuretype list. And checking the postgis database Geoserver has added the versioning tables { changesets, tables changed and versioned_tables }.
At this point I try to use the version feature using a GetVersionedFeature and Geoserver complains that my database is not a versioned database.
