Error creating bean with name 'config'
Key: GEOS-1714
URL: http://jira.codehaus.org/browse/GEOS-1714
Project: GeoServer
Issue Type: Sub-task
Affects Versions: 1.6.0-RC3
Environment: Windows XP
Reporter: berlotti
Assignee: Andrea Aime
I get kind of the same error on startup in Windows XP.
C:\Program Files\GeoServer 1.6.0-RC3>C:\Progra~1\Java\jdk1.6.0_03\bin\java.exe -
DGEOSERVER_DATA_DIR="%GEOSERVER_DATA_DIR%" -Xmx300m -DSTOP.PORT=8079 -DSTOP.KEY=
geoserver -jar start.jar
0 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com vi
a org.mortbay.log.Slf4jLog
203 [main] INFO org.mortbay.log - jetty-6.0.2
1046 [main] INFO /geoserver - Loading Spring root WebApplicationContext
29 jan 12:54:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: C:\geodatadir
29 jan 12:54:39 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean wit
h name 'config' defined in URL [jar:file:/C:/Program%20Files/GeoServer%201.6.0-R
C3/webapps/geoserver/WEB-INF/lib/main-1.6.0-RC3.jar!/applicationContext.xml]: In
itialization of bean failed; nested exception is java.lang.NullPointerException:
null
