[Geoserver-devel] [jira] Created: (GEOS-172) Adjustable srs style in output GML
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/browse/GEOS-172
Here is an overview of the issue:
        Key: GEOS-172
    Summary: Adjustable srs style in output GML
       Type: Improvement
     Status: Open
   Priority: Minor
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             WFS
   Fix Fors:
             1.2.0
   Versions:
             1.2.0-rc1
   Assignee: Chris Holmes
   Reporter: Chris Holmes
    Created: Fri, 4 Jun 2004 1:35 AM
    Updated: Fri, 4 Jun 2004 1:35 AM
Description:
It looks like a number of clients assume that the srs reported in gml will be of the style srsName="EPSG:4326" instead of the srsName="http:////www.opengis.net/gml/srs/epsg.xml#4326", which is what the wfs spec says. We need to investigate the gml spec to see what is the 'correct' way, but I think it would be nice for interoperability purposes to support the other epsg style, as CadCorp did things this way (they now have a patch to support it), and I believe this is where Deegree falls short as well. Not sure if we want to switch everything over, but we can just make it a user config option.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
