GeoServer should accept coverage store names with leading numerals
Key: GEOS-1735
URL: http://jira.codehaus.org/browse/GEOS-1735
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.6.0-RC3
Reporter: Amos Hayes
Assignee: Andrea Aime
Creating a coverage Store with the name "1849_vidal_anderson_rh_map_rectified" produces the following error:
Coverage Data Set ID '1849_vidal_anderson_rh_map_rectified' must contain only alphanumeric characters (A-Z, a-z, 0-9)
Creating a coverage store with the name "a1849_vidal_anderson_rh_map_rectified" works.
