Ampersand in format description in catalog.xml causes failure to start geoserver
Key: GEOS-1738
URL: http://jira.codehaus.org/browse/GEOS-1738
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.6.0-RC3
Environment: GeoServer 1.6.0 RC3 on Java 1.5 on OS X 10.4
Reporter: Amos Hayes
Assignee: Andrea Aime
Including a description to a coverage store which contains an ampersand (&) works while geoserver is up. But GeoServer will not restart.
The following in catalog.xml:
<format namespace = "glsl" enabled = "true" id = "general1811robhuron_4326.tif" >
<description>CANADA / BY A. K. JOHNSTON F. R. G. S. // NATIONAL ATLAS // 38 //
Engraved by W. & A. K. Johnston. // [above the title overprinted
"LITHOGRAPHED EDITION" has been added in sepia] // [imprint at bottom
of sheet is partially cut off]
Alexander Keith Johnston (1804-1871), published [1849?].
Printed map. 50 cm x 61 cm, on sheet 52 cm x 64 cm. Boundaries and
outlines coloured. Gilt edges.
Scale: Two visual scales [67 mm = 90 Geographical Miles & 63 mm = 100
English Miles].
Taken from same original source as Accession # 107382.
Acquired as part of the Hodsoll Collection. </description>
<type>GeoTIFF</type>
<url>file:coverages/glsl/general1811robhuron_4326.tif</url>
</format>
will generate this error:
[Fatal Error] :79:17: The entity name must immediately follow the '&' in the entity reference.
11 Feb 16:42:25 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'config' defined in URL [jar:file:/usr/local/apache-tomcat-6.0.14/webapps/geo
server/WEB-INF/lib/main-1.6.0-RC3.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: Error reading : java.
io.InputStreamReader@anonymised.com
java.lang.RuntimeException: Error reading : java.io.InputStreamReader@anonymised.com
at org.geoserver.util.ReaderUtils.parse(ReaderUtils.java:90)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:364)
at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:222)
at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:176)
at org.vfny.geoserver.global.Config.setApplicationContext(Config.java:90)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:84)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFacto
ry.java:248)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:362)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:312)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:275)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:318)
at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3830)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4337)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:525)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:825)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:714)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:490)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1138)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:566)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Caused by: org.xml.sax.SAXParseException: The entity name must immediately follow the '&' in the entity reference.
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at org.geoserver.util.ReaderUtils.parse(ReaderUtils.java:87)
... 42 more
Feb 11, 2008 4:42:25 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/geoserver] startup failed due to previous errors
