[Geoserver-devel] [jira] Created: (GEOS-1740) WMS Reprojection won't work when the original data does not have an SRS at all
                 Key: GEOS-1740
                 URL: http://jira.codehaus.org/browse/GEOS-1740
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.0
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 1.6.1
Overlaying a map with google maps background fails if the original data srs is not set.
For example, try to import the states shapefile into postgis without specifying an srs, force 4326 in the feature type UI, and then try to overlay with Google Maps cartography altering the srs demo... nothing will show (in fact the test was carried out using the kanagawa dataset from pg_routing).
One can say this is a misconfiguration on the user part, but on the other side the user did force the 4326 projection in the feature type panel.
