[Geoserver-devel] [jira] Created: (GEOS-1746) Versioning installation problems
                 Key: GEOS-1746
                 URL: http://jira.codehaus.org/browse/GEOS-1746
             Project: GeoServer
          Issue Type: Bug
          Components: PostGIS
    Affects Versions: 1.6.0
         Environment: Linux
            Reporter: Scot E. Wilcoxon
            Assignee: Andrea Aime
Only installation instructions seem to be within the Versioning download, in data_dir/README.txt.
1. Instructions do not state that "spearfish" database must be converted from PostgreSQL to PostGIS.
2. When converting to PostGIS with the lwpostgis.sql script errors occur:
CREATE FUNCTION
lwpostgis.sql:1257: ERROR: unterminated quoted string at or near "'
BEGIN
EXECUTE ''SET local search_path = ''||$2||'',public'';"
LINE 12: AS '
lwpostgis.sql:1258: ERROR: syntax error at or near "RETURN"
LINE 3: RETURN public.build_histogram2d($1,$3,$4);
... etc.
