[Geoserver-devel] [jira] Created: (GEOS-1747) PartialBufferOutputStream2 flush issues
                 Key: GEOS-1747
                 URL: http://jira.codehaus.org/browse/GEOS-1747
             Project: GeoServer
          Issue Type: Bug
          Components: Global
    Affects Versions: 1.6.0
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.6.1, 1.7.0-beta1
PartialBufferOutputStream2 is wrongly flushing the buffer contents on a flush() call, even if it's still working on the in memory buffer.
This may lead to failure to report service exception if the code encoding the output calls flush() before having written the full contents to the output (this happens in particular when reporting exceptions in the mime multipart code used by wcs 1.1.1, but the vulnerability is general)
