[Geoserver-devel] [jira] Created: (GEOS-1752) GetFeatureInfo does not work on layer whose srs was reprojected at the configuration level
                 Key: GEOS-1752
                 URL: http://jira.codehaus.org/browse/GEOS-1752
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.0
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.6.1
Open the topp:states configuration panel, change the srs to 900913, change srs handling to reproject, preview and try to get feature infos. It won't work.
This is due to a wms optimization that should not be used in the getfeatureinfo case, that is, avoid the reprojection at the datastore level since the renderer can reprojection a lot more efficiently.
Unfortunately in the case of GetFeatureInfo the renderer is out of the picture and the datastore level reprojection is required.
