Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/browse/GEOS-176
Here is an overview of the issue:
Key: GEOS-176
Summary: Test internationalization
Type: Task
Status: Open
Priority: Minor
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Fix Fors:
1.2.0
Versions:
1.2.0-rc1
Assignee: Chris Holmes
Reporter: Chris Holmes
Created: Fri, 4 Jun 2004 6:12 PM
Updated: Fri, 4 Jun 2004 6:12 PM
Description:
We allow users to specify a charSet, but haven't tested this in quite some time. Need to make sure it still works, specifying different mime types and displaying in browsers correctly. This needs to work both for information written in files, like services.xml and catalog.xml, as well as in the backend database. Supposedly postgis 7.2 and above should not need any connection level character sets, all should be compiled with support for all character sets, I believe. So this should be tested, and the setEncoding stuff should be removed. Also should test to see if the web config tool will let you input weird characters and save them correctly.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
