[Geoserver-devel] [jira] Created: (GEOS-1760) Unit tests fail in path with spaces
                 Key: GEOS-1760
                 URL: http://jira.codehaus.org/browse/GEOS-1760
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.6.x
         Environment: Windows XP i386
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
            Priority: Minor
Unit tests fail when the path to the working directory contains spaces.
Procedure to repeat:
mkdir "path with spaces"
cd "path with spaces"
svn export https://svn.codehaus.org/geoserver/branches/1.6.x GeoServer-1.6
cd GeoServer-1.6\geoserver
mvn install
Result: Build fails with many, many unit test failures. For example:
Test set: org.geoserver.wfs.GeometrylessTest
Tests run: 8, Failures: 0, Errors: 8, Skipped: 0, Time elapsed: 4.876 sec <<< FAILURE!
testGetFeature10(org.geoserver.wfs.GeometrylessTest) Time elapsed: 0.563 sec <<< ERROR!
java.io.IOException: Could not write catalog to .\target\mock49894data\catalog.xml
  at org.geoserver.data.CatalogWriter.write(CatalogWriter.java:204)
  at org.geoserver.data.test.MockData.setUp(MockData.java:414)
  at org.geoserver.data.test.MockData.setUp(MockData.java:314)
  at org.geoserver.test.GeoServerTestSupport.setUp(GeoServerTestSupport.java:93)
  at junit.framework.TestCase.runBare(TestCase.java:125)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:138)
  at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:125)
  at org.apache.maven.surefire.Surefire.run(Surefire.java:132)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:308)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:879)
Caused by: javax.xml.transform.TransformerException: java.io.FileNotFoundException: C:\Users\car605\path%20with%20spaces\GeoServer-1.6\geoserver\wfs\.\target\mock49894data\catalog.xml (The system cannot find the path specified)
  at org.apache.xalan.transformer.TransformerIdentityImpl.createResultContentHandler(TransformerIdentityImpl.java:296)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:329)
  at org.geoserver.data.CatalogWriter.write(CatalogWriter.java:201)
  ... 24 more
Caused by: java.io.FileNotFoundException: C:\Users\car605\path%20with%20spaces\GeoServer-1.6\geoserver\wfs\.\target\mock49894data\catalog.xml (The system cannot find the path specified)
  at java.io.FileOutputStream.open(Native Method)
  at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
  at java.io.FileOutputStream.<init>(FileOutputStream.java:70)
  at org.apache.xalan.transformer.TransformerIdentityImpl.createResultContentHandler(TransformerIdentityImpl.java:286)
  ... 26 more
  ... 26 more
