/geoserver not found http 404 error
Key: GEOS-1780
URL: http://jira.codehaus.org/browse/GEOS-1780
Project: GeoServer
Issue Type: Bug
Components: WMS
Environment: HOSTGIS DISTRO
Reporter: Drew Trainum
Assignee: Andrea Aime
Priority: Critical
after loading around 20-30 maps
if you go to the geoserve on the server it gives you this error
HTTP ERROR: 404
NOT_FOUND
RequestURI=/geoserver/
Powered by jetty://
GEOSERVER DATA DIR is /usr/geoserver/data_dir
java.net.BindException: Address already in use
WARN: Not listening on monitor port: 8079
3 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com via org.mortbay.log.Slf4jLog
863 [main] INFO org.mortbay.log - jetty-6.0.1
2247 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
2247 [main] INFO /geoserver - Loading Spring root WebApplicationContext
2428 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [jar:file:/usr/geoserver/webapps/geos$
2617 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [jar:file:/usr/geoserver/webapps/geos$
2666 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [file:/usr/geoserver/webapps/geoserve$
2721 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [jar:file:/usr/geoserver/webapps/geos$
2863 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [jar:file:/usr/geoserver/webapps/geos$
3230 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [jar:file:/usr/geoserver/webapps/geos$
3297 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [jar:file:/usr/geoserver/webapps/geos$
3407 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [Root WebApplicationContext]: org.s$
3435 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - 72 beans defined in application context [Root WebApplicationContext]
3491 [main] INFO org.springframework.core.CollectionFactory - Commons Collections 3.x available
3513 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Unable to locate MessageSource with name 'messageSource': using default $
3529 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Unable to locate ApplicationEventMulticaster with name 'applicationEvent$
3540 [main] INFO org.springframework.ui.context.support.UiApplicationContextUtils - Unable to locate ThemeSource with name 'themeSource': using default [org$
3549 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in factory [org.springframework.beans.f$
- GEOSERVER_DATA_DIR: /usr/geoserver/data_dir
Feb 29, 2008 10:53:53 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /root/.java/.userPrefs/org/vfny/geoserver/global/prefs.xml
11 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - logging level is CONFIG
16 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - maxFeatures is 1000000
17 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - numDecimals returning is 8
17 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - charSet is UTF-8
27 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - reading srsXmlStyle: [srsXmlStyle: null]
3258 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading configuration file: /usr/geoserver/data_dir/catalog.xml
[Fatal Error] :72:74: The reference to entity "subdivisions" must end with the ';' delimiter.
7087 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in factory {org.springframework.beans.factory.$
7088 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validation' defined in URL [jar:file:/usr/geoserver/webapps/geoserve$
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'config' defined in URL [jar:file:/usr/geoserver/webapps/geoserver/WE$
java.lang.RuntimeException: Error reading : java.io.InputStreamReader@anonymised.com
at org.geoserver.util.ReaderUtils.parse(ReaderUtils.java:72)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:323)
at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:197)
at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:155)
at org.vfny.geoserver.global.Config.setApplicationContext(Config.java:69)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:84)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableB$
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:362)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:176)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:105)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.resolveConstructorArguments(AbstractAutowireCapableBeanFactory.java:$
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:611)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:329)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:275)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: org.xml.sax.SAXParseException: The reference to entity "subdivisions" must end with the ';' delimiter.
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at org.geoserver.util.ReaderUtils.parse(ReaderUtils.java:69)
... 43 more
7095 [main] WARN org.mortbay.log - failed ContextHandler@anonymised.com{/geoserver,file:/usr/geoserver/webapps/geoserver/}
7095 [main] WARN org.mortbay.log - failed ContextHandlerCollection@anonymised.com
7111 [main] WARN org.mortbay.log - failed HandlerCollection@anonymised.com
7130 [main] WARN org.mortbay.log - failed SelectChannelConnector @ 0.0.0.0:8080
7130 [main] WARN org.mortbay.log - failed Server@anonymised.com
7130 [main] WARN org.mortbay.log - EXCEPTION
org.mortbay.util.MultiException[org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validation' defined in URL [jar:file$
at org.mortbay.jetty.Server.doStart(Server.java:192)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:38)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:905)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
