override an existing EPSG definition in the property file
Key: GEOS-1783
URL: http://jira.codehaus.org/browse/GEOS-1783
Project: GeoServer
Issue Type: Wish
Components: Configuration
Affects Versions: 1.6.0
Reporter: Bart van den Eijnden
Assignee: Andrea Aime
Priority: Minor
It would be nice if you can override the projection parameters of an existing EPSG definition (which is present in the HSQL database) in the epsg property file.
This is for instance handy for the Dutch national grid, since the towgs84 parameters are not in the EPSG database, and therefore the default Geoserver won't reproject accurately between RD and WGS84.
