[Geoserver-devel] [jira] Created: (GEOS-181) Unable to Connect to Oracle Datastore on Server Startup
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/browse/GEOS-181
Here is an overview of the issue:
        Key: GEOS-181
    Summary: Unable to Connect to Oracle Datastore on Server Startup
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             Oracle
   Versions:
             1.2.0
   Assignee: Sean Geoghegan
   Reporter: Ian Ives
    Created: Thu, 24 Jun 2004 1:01 PM
    Updated: Thu, 24 Jun 2004 1:01 PM
Environment: Windows XP Professional, Jakarta Tomcat 4.1.30, Java 1.4.2_03, Oracle DB 9.2.0.4
Description:
Migrated my Application from version 1.1.1 to 1.2.0-rc2. Was unable to connect to the Oracle Datastore on start-up of the server. Error message as follows:
1052 [SEVERE] org.vfny.geoserver.global.Data - FeatureTypeInfo remote.Oracle:::TEST_WFS ignored - as DataStore remote.Oracle is broken:java.util.NoSuchElementException: No datastore found capable of managing DataStoreConfig[namespace=topp, enabled=true, abstract=A remote oracle database, connection parameters={namespace=http://www.openplans.org/topp, user=geoserv, instance=dev9is, passwd=geoserv, host=hol-lx-dev04, port=1521, dbtype=oracle}]
        at org.vfny.geoserver.global.DataStoreInfo.getDataStore(DataStoreInfo.java:223)
        at org.vfny.geoserver.global.Data.loadFeatureTypes(Data.java:354)
        at org.vfny.geoserver.global.Data.load(Data.java:164)
        at org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:108)
        at org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1158)
        at org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
        at javax.servlet.GenericServlet.init(GenericServlet.java:256)
        at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:935)
        at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:823)
        at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:3427)
        at org.apache.catalina.core.StandardContext.start(StandardContext.java:3628)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:821)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:807)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:595)
        at org.apache.catalina.core.StandardHostDeployer.install(StandardHostDeployer.java:307)
        at org.apache.catalina.core.StandardHost.install(StandardHost.java:788)
        at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:492)
        at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:400)
        at org.apache.catalina.startup.HostConfig.start(HostConfig.java:718)
        at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:358)
        at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:166)
        at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1196)
        at org.apache.catalina.core.StandardHost.start(StandardHost.java:754)
        at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1188)
        at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:363)
        at org.apache.catalina.core.StandardService.start(StandardService.java:497)
        at org.apache.catalina.core.StandardServer.start(StandardServer.java:2190)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:512)
        at org.apache.catalina.startup.Catalina.execute(Catalina.java:400)
        at org.apache.catalina.startup.Catalina.process(Catalina.java:180)
        at java.lang.reflect.Method.invoke(Method.java:324)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:203)
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
