GeoServer throws this error intermittently when requesting a RSS feed through a CQL Filter.
Key: GEOS-1812
URL: http://jira.codehaus.org/browse/GEOS-1812
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.6.0
Environment: Ubuntu 7.10, Java 1.6.0 Sun, Tomcat 6
Reporter: Ivan Willig
Assignee: Andrea Aime
17 Mar 14:42:00 WARN [geoserver.ows]
java.io.IOException
at org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSMapProducer.writeTo(RSSGeoRSSMapProducer.java:49)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:531)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:584)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
at org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSMapProducer.writeTo(RSSGeoRSSMapProducer.java:47)
... 43 more
Caused by: java.lang.IllegalStateException: Cannot create a session after the response has been committed
at org.apache.catalina.connector.Request.doGetSession(Request.java:2301)
at org.apache.catalina.connector.Request.getSession(Request.java:2075)
at org.apache.catalina.connector.RequestFacade.getSession(RequestFacade.java:833)
at org.apache.catalina.connector.RequestFacade.getSession(RequestFacade.java:844)
at org.vfny.geoserver.util.Requests.getBaseUrl(Requests.java:87)
at org.geoserver.wms.util.WMSRequests.getBaseUrl(WMSRequests.java:45)
at org.geoserver.wms.util.WMSRequests.getBaseUrl(WMSRequests.java:60)
at org.geoserver.wms.util.WMSRequests.getGetMapUrl(WMSRequests.java:131)
at org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformer$RSSGeoRSSTranslator.encode(RSSGeoRSSTransformer.java:74)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
... 45 more
