[Geoserver-devel] [jira] Created: (GEOS-1822) Better error message for database permission problems
                 Key: GEOS-1822
                 URL: http://jira.codehaus.org/browse/GEOS-1822
             Project: GeoServer
          Issue Type: Improvement
          Components: UI
    Affects Versions: 1.6.1
            Reporter: Teemu Välimäki
            Assignee: Andrea Aime
            Priority: Minor
I was about to create a new FeatureType from Postgis DataStore, when GS webgui told, that the SRS could not be found (GS placed -1 on the SRS input field) and when manually entered GS could not calculate BBOX values. The error message was misleading, when it tried to hint me about empty dataset or not having default geometry attribute.
The real problem was, that the Postgres account didn't have query access to table spatial_ref_sys.
Error what GS gave was
{quote}
The FeatureType 'laa_akseli' has a NULL extent.
HINT: the dataset is empty or has no default geometry attribute.
{quote}
GS logged this
{quote}
2008-03-20 12:20:44,280 WARN [org.geotools.data.jdbc] - Error building attribute type. The column will be ignored org.geotools.data.DataSourceException: ERROR: permission denied for relation spatial_ref_sys
{quote}
