Compatibility checking for Extensions
Key: GEOS-1824
URL: http://jira.codehaus.org/browse/GEOS-1824
Project: GeoServer
Issue Type: Wish
Components: Configuration
Reporter: Scot E. Wilcoxon
Assignee: Andrea Aime
Priority: Trivial
Because Extensions such as Versioning and GML are downloaded and installed as separate steps, it is possible for incompatible code (or data) to be installed. I suggest that version labels be defined in data and code extensions. Eventually compatibility code should be added to reduce or report incompatible extensions.
