[Geoserver-devel] [jira] Created: (GEOS-1830) Allow to limit the list of available CRS's in WMS GetCapabilities
                 Key: GEOS-1830
                 URL: http://jira.codehaus.org/browse/GEOS-1830
             Project: GeoServer
          Issue Type: Improvement
          Components: Configuration, WMS
    Affects Versions: 1.6.3
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 1.6.3
The WMS capabilities document currently exposes the list of all the geoserver supported CRS's.
That means 3900+ elements of the type {{<SRS>EPSG:2588</SRS>}}, which, by one side, kills most javascript based WMS clients when trying to parse the GetCapabilities document. And by the other hand it makes sense for an installation to expose those CRS codes that make sense for the actual data being served.
This issue though, is not meant to actually limit the list of CRS's geoserver can operate with, but to just limit the list of exposed ones. So if a request is made over a supported CRS that is not listed in the capabilities document, it should keep working anyways.
Also, a very basic user interface configuration element shall be included, so its not that hard for users to specify the list of CRS's. This may be as simple as a text area in which to write a comma separated list of epsg codes to expose.
