[Geoserver-devel] [jira] Created: (GEOS-1837) Postgis backend is spamming logs
                 Key: GEOS-1837
                 URL: http://jira.codehaus.org/browse/GEOS-1837
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.6.2
            Reporter: Arne Kepp
            Assignee: Andrea Aime
            Priority: Blocker
             Fix For: 1.6.3
# tail catalina.out
SELECT "module", "land", "laname", "cfcc_1", "cfcc_2", "cfcc", encode(asBinary(force_2d("the_geom"),'XDR'),'base64')
SELECT "module", "polyid", encode(asBinary(force_2d("the_geom"),'XDR'),'base64')
SELECT "fid", "interstate", "ushighway", "statehighway", encode(asBinary(force_2d("gen_full"),'XDR'),'base64'), "othername"
SELECT "oid", encode(asBinary(force_2d("gen_full"),'XDR'),'base64')
SELECT "oid", "name", "population", encode(asBinary(force_2d("the_geom"),'XDR'),'base64')
(Data collected on geo.openplans.org)
