Build failure in community/rest on annotations
Key: GEOS-1839
URL: http://jira.codehaus.org/browse/GEOS-1839
Project: GeoServer
Issue Type: Bug
Environment: Windows XP i386, jdk1.5.0_14
Reporter: Ben Caradoc-Davies
Assignee: Andrea Aime
Fix For: 1.6.x
Build with "mvn install" fails in community/rest on community\rest\src\test\java\org\geoserver\rest\MapResourceTest.java
which uses annotations. Maven is set for -source 1.3 at this point.
Tail of output:
[INFO] -------------------------------------------------------------------------
[INFO] Building Geoserver REST Support Code
[INFO] task-segment: [eclipse:clean, clean, install, eclipse:eclipse]
[INFO] [eclipse:clean]
[INFO] Deleting file: .project
[INFO] Deleting file: .classpath
[INFO] Deleting file: .wtpmodules
[INFO] Deleting file: .component
[INFO] Deleting file: org.eclipse.wst.common.component
[INFO] Deleting file: org.eclipse.wst.common.project.facet.core.xml
[INFO] Deleting file: org.eclipse.jdt.core.prefs
[INFO] [clean:clean]
[INFO] Deleting directory C:\Users\car605\geoserver\src\GeoServer-1.6\geoserver\
community\rest\target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 11 source files to C:\Users\car605\geoserver\src\GeoServer-1.6\
geoserver\community\rest\target\classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 2 source files to C:\Users\car605\geoserver\src\GeoServer-1.6\g
eoserver\community\rest\target\test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
C:\Users\car605\geoserver\src\GeoServer-1.6\geoserver\community\rest\src\test\ja
va\org\geoserver\rest\MapResourceTest.java:[25,17] annotations are not supported
in -source 1.3
(try -source 1.5 to enable annotations)
@Override
in -source 1.3
@Override
[INFO] Total time: 37 seconds
[INFO] Finished at: Wed Apr 02 12:23:54 WST 2008
[INFO] Final Memory: 29M/54M
