[Geoserver-devel] [jira] Created: (GEOS-1841) Without Default namespace all requests fail
                 Key: GEOS-1841
                 URL: http://jira.codehaus.org/browse/GEOS-1841
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.6.2
            Reporter: Teemu Välimäki
            Assignee: Andrea Aime
         Attachments: error.txt
I removed all example configurations from GS even the topp* Namespace. After this requests with valid namespace prefix failed to show ending up in java null exception. My requests contain LAYERS=map:layername, where map is a correct namespace that I have created. Even with a valid request where namespace was defined the process fails.
Workaround for the problem was to create a dumb namespace defined as Default. This namespace is not used to anything else.
