Build failure in community/csv (invalid POM)
Key: GEOS-1844
URL: http://jira.codehaus.org/browse/GEOS-1844
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.6.x
Reporter: Ben Caradoc-Davies
Assignee: Andrea Aime
[after a local hack to workaround GEOS-1843]
C:\Users\car605\geoserver\src\GeoServer-1.6\geoserver\community>mvn -Pcommunity-
schemas eclipse:clean clean install eclipse:eclipse
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geoserver:csv
POM Location: C:\Users\car605\geoserver\src\GeoServer-1.6\geoserver\community\cs
v\pom.xml
Validation Messages:
[0] 'dependencies.dependency.version' is missing for commons-io:commons-io
Reason: Failed to validate POM
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Failed to validate POM
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:373)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:286)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:123)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:272)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Failed to vali
date POM
at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLog
ic(DefaultMavenProjectBuilder.java:949)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(Def
aultMavenProjectBuilder.java:760)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFi
leInternal(DefaultMavenProjectBuilder.java:431)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMave
nProjectBuilder.java:195)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:523)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:455)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:499)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:359)
... 11 more
[INFO] Total time: < 1 second
[INFO] Finished at: Thu Apr 03 11:38:51 WST 2008
[INFO] Final Memory: 1M/3M
