[Geoserver-devel] [jira] Created: (GEOS-1854) Like on dates fails during cite wfs 1.1 tests againsg postgres 8.3
                 Key: GEOS-1854
                 URL: http://jira.codehaus.org/browse/GEOS-1854
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.6.2
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.6.4, 1.7.0-beta1
Running the following wfs query against geoserver + postgres 8.3
{code:xml}
<wfs:GetFeature xmlns:sf="http://cite.opengeospatial.org/gmlsf&quot;
                xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot;
                xmlns:ogc="http://www.opengis.net/ogc&quot;
                xmlns:saxon="http://saxon.sf.net/&quot;
                xmlns:p="http://teamengine.sourceforge.net/parsers&quot;
                xmlns:xlink="http://www.w3.org/1999/xlink&quot;
                xmlns:gml="http://www.opengis.net/gml&quot;
                xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
                xmlns:ows="http://www.opengis.net/ows&quot;
                xmlns:ctl="http://www.occamlab.com/ctl&quot;
                xmlns:xi="http://www.w3.org/2001/XInclude&quot;
                xmlns:te="java:com.occamlab.te.TECore"
                xmlns:parsers="http://www.occamlab.com/te/parsers&quot;
                xmlns="http://www.occamlab.com/ctl&quot;
                xmlns:myparsers="http://teamengine.sourceforge.net/parsers&quot;
                xmlns:wfs="http://www.opengis.net/wfs&quot;
                service="WFS"
                version="1.1.0">
         <wfs:Query srsName="urn:x-ogc:def:crs:EPSG:6.11.2:4326" typeName="sf:PrimitiveGeoFeature">
            <ogc:Filter>
               <ogc:PropertyIsLike escapeChar="\" singleChar="?" wildCard="*">
                  <ogc:PropertyName>sf:dateProperty</ogc:PropertyName>
                  <ogc:Literal>20*-10-??</ogc:Literal>
               </ogc:PropertyIsLike>
            </ogc:Filter>
         </wfs:Query>
      </wfs:GetFeature>
{code}
results in the following query:
{code}
cite=# SELECT "id", "description", "name", encode(asBinary(force_2d("surfaceProp
erty"),'XDR'),'base64'), encode(asBinary(force_2d("pointProperty"),'XDR'),'base6
4'), encode(asBinary(force_2d("curveProperty"),'XDR'),'base64'), "intProperty", "uriProperty", "measurand", "dateTimeProperty", "dateProperty", "decimalProperty "
FROM "public"."PrimitiveGeoFeature"
WHERE ( "dateProperty" LIKE '20%-10-__' OR "dateProperty" LIKE '20%-10-__ __:__:__' OR "dateProperty" LIKE '20%-10-__ __:__:_____' );
{code}
that works fine on my postgres 8.1.5, but fails with the following error message on gridlock's windows VM:
{code}
ERROR: operator does not exist: timestamp with time zone ~~ unknown
LINE 1: ...ic"."PrimitiveGeoFeature" WHERE ( "dateProperty" LIKE '20%-...
HINT: No operator matches the given name and argument type(s). You might need to add explicit type casts.
{code}
Modifying the query as follows (explicit cast of fields to varchar) make it work on pg 8.3 as well:
{code}
" FROM "public"."PrimitiveGeoFeature" WHERE ( "dateProperty"::varchar LIKE '20%
-10-__' OR "dateProperty"::varchar LIKE '20%-10-__ __:__:__' OR "dateProperty":
:varchar LIKE '20%-10-__ __:__:_____' );
{code}
