[Geoserver-devel] [jira] Created: (GEOS-1857) Change project icons to match geoserver.org
                 Key: GEOS-1857
                 URL: http://jira.codehaus.org/browse/GEOS-1857
             Project: GeoServer
          Issue Type: Improvement
          Components: UI
    Affects Versions: 1.6.3
         Environment: Windows
            Reporter: Mike Pumphrey
            Assignee: Mike Pumphrey
            Priority: Trivial
             Fix For: 1.6.4
Change GeoServer icons on Windows builds to match the graphic that is on geoserver.org .
