[Geoserver-devel] [jira] Created: (GEOS-186) Fids on tables with no primary key should default to oid
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/browse/GEOS-186
Here is an overview of the issue:
        Key: GEOS-186
    Summary: Fids on tables with no primary key should default to oid
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
   Fix Fors:
             1.2.0
   Versions:
             1.2.0-rc2
   Assignee: Chris Holmes
   Reporter: Chris Holmes
    Created: Sat, 26 Jun 2004 5:24 PM
    Updated: Sat, 26 Jun 2004 5:24 PM
Description:
The fid-exp changes have made it so postgis tables that don't have primary keys declared show up with very strange fid values. These should instead just default to the oid. Just need to modify the fidmapper strategies, make a new one for oid, I believe.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
