org.vfny.geoserver.config.CoverageConfig causes memory overflow
Key: GEOS-1868
URL: http://jira.codehaus.org/browse/GEOS-1868
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.6.3
Environment: all platforms
Reporter: Christian Mueller
Assignee: Andrea Aime
I am developing and image mosaicing/pyradmid plugin for geotools and did some tests with geoserver.
The size of the pyramids are beyond some Gigs and the constructor of CoverageConfig does a test read using 1/20 of the width and hight of the full extent. That is to much and causes a memory overflow.
