[Geoserver-devel] [jira] Created: (GEOS-1909) CITE WFS 1.1 failure after prepared statement usage in postgis data store
                 Key: GEOS-1909
                 URL: http://jira.codehaus.org/browse/GEOS-1909
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.6.3
            Reporter: Andrea Aime
            Assignee: Gabriel Roldán
            Priority: Blocker
             Fix For: 1.6.4, 1.7.0-beta1
Introducing the prepared statement usage broke one of the cite tests. This is because the wfs request parser generates a string instead of a number, and the string is set directly in the prepared statemetn with no conversion.
If the attribute type is "long" or "double" some conversion must occurr, either in the parser or in the datastore, to account for the type discrepancy.
The test is wfs:wfs-1.1.0-Transaction-tc4.1, the update is
{code:xml}
<wfs:Update handle="upd-1" typeName="sf:PrimitiveGeoFeature">
            <wfs:Property>
               <wfs:Name>sf:measurand</wfs:Name>
               <wfs:Value>286.0</wfs:Value>
            </wfs:Property>
            <ogc:Filter>
               <ogc:PropertyIsEqualTo matchCase="false">
                  <ogc:PropertyName>gml:name</ogc:PropertyName>
                  <ogc:Literal>cite.gmlsf0-f07</ogc:Literal>
               </ogc:PropertyIsEqualTo>
            </ogc:Filter>
         </wfs:Update>
{code}
The generated query is now:
UPDATE "public"."PrimitiveGeoFeature" SET "measurand" = ? WHERE lower("name") = lower('cite.gmlsf0-f07');
and ? gets replaced with "286.0" instead of new Double(286.0) leading to a database error
