[Geoserver-devel] [jira] Created: (GEOS-1914) Inability to parse a kvp filter result in hard to understand error message
                 Key: GEOS-1914
                 URL: http://jira.codehaus.org/browse/GEOS-1914
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.6.3
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
            Priority: Critical
             Fix For: 1.6.4
The following request:
http://localhost:8080/geoserver/wfs?request=getfeature&service=wfs&version=1.0.0&typename=topp:r1kdata&filter=<ogc%3AFilter><ogc%3APropertyIsEqualTo><ogc%3APropertyName>STATE_NAME</ogc%3APropertyName><ogc%3ALiteral>New%20York</ogc%3ALiteral></ogc%3APropertyIsEqualTo></ogc%3AFilter>%20
Using the filter:
{code:xml}
<ogc:Filter><ogc:PropertyIsEqualTo><ogc:PropertyName>STATE_NAME</ogc:PropertyName><ogc:Literal>New York</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
{code}
results in:
{code}
09 mag 14:42:10 WARN [geoserver.ows] -
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
  at java.util.ArrayList.RangeCheck(ArrayList.java:547)
  at java.util.ArrayList.get(ArrayList.java:322)
  at org.geotools.xml.EMFUtils.set(EMFUtils.java:143)
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.querySet(GetFeatureKvpRequestReader.java:279)
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:126)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1016)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:385)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:185)
{code}
This happens because in the filter kvp parser the new parser fails to handle the filter, the old parser fails as well, and the return value is an empty collection which the EMF reflection in the dispatcher cannot handle properly (the first parser throws an exception, the second one returns null).
Imho we should throw an exception stating the filter is invalid instead of keep on going on when none of the parsers can handle the filter.
What do you think?
