GetFeatureInfo does not properly handle multi layer filters
Key: GEOS-1916
URL: http://jira.codehaus.org/browse/GEOS-1916
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.6.3
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.6.5
Try a preview with the following url:
http://localhost:8080/geoserver/wms?bbox=-127.61950111389118,23.73517837524415,-64.08176994323732,50.59252700805665&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:pgstates&width=800&height=317&srs=EPSG:4326&featureId=states.1,states.2,states.3
and then click on the map, the GetFeatureInfo response will be:
"1 layers requested, but found 3 filters specified. When you specify the FILTER parameter, you must provide just one, that will be applied to all layers, or exactly one for each requested layer "
Apparently featureId handling is not working properly. Also check other filter types
