Error tiles over map
Key: GEOS-1922
URL: http://jira.codehaus.org/browse/GEOS-1922
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.6.3
Environment: Wibndows XP and Vista
Reporter: william Jay
Assignee: Andrea Aime
Attachments: ol-demo.html
I have set up a Geoserver with 3 layers of my own. I used the Ol-Demo template with the 3 sattelite backgrounds, and added my layers to it. On the Geoserver the map works perfectly. You can swap back and forth between the Google Map, Yahoo, and Virtual Earth, and all 3 added layers come up fine. But god forbid I try to access it from another computer. It tiles over the map with large error tiles no matter which sattelite background I use, and it then will not load any of my layers. I am hosting locally at the moment, because this issue is literally the last hurdle before I can send it to our hosting company. Has anyone run into this problem? It's very frustrating.
